Manage the WebLogic Server
You may need to stop and then restart the WebLogic server
for the following reasons:
- After registering BI Publisher server with SDM, you must stop the WebLogic server before restarting the Weblogic server again.
- SSL needs to be reenabled for HTTPS mode.
- The BI Publisher security model is enabled with the single sign-on (SSO) feature.
