Install the Oracle Business Intelligence 12c Configuration Assistant
Now that the Oracle Fusion Middleware and Oracle Business Intelligence 12c software is installed, you must install the Oracle Business Intelligence 12c Configuration Assistant.
Any values that you configure in this section, save a record of them for future use.-
Ensure that the
listener is running. Refer to the
How to Start, Stop, and Check the Status of the
Oracle Database Listener section for more information. Look for the
expected result in the status display:
Service "AcmeBIPublisXDB" has 1 instance(s). Instance "AcmeBIPublis", status READY, has 1 handler(s) for this service... Service "AcmeBIPublisher" has 1 instance(s). Instance "AcmeBIPublis", status READY, has 1 handler(s) for this service... Service "orcl" has 1 instance(s).
Change the
directory to the bin directory that was created for you as part of the Oracle
Business Intelligence 12c installation. For example:
/home/oracle/Oracle/Middleware/Oracle_Home/bi/bin
Install the Oracle
Business Intelligence 12c Configuration Assistant with the config.sh script:
./config.sh
In the
Welcome window,
uncheck the
Essbase and
Business
Intelligence Enterprise Edition check boxes under the
Components
to include header and click
Next.
- In the Prerequisite Checks window, click Next when the prerequisite checks are completed.
In the
Define New
Domain window, the location and credential information is populated
in their respective fields, enter the password credentials for the Weblogic
server in the
Credentials
for new domain section (you will use these credentials later when
you login to the Weblogic server) and click
Next. For example:
In the
Database
Schema window, you are creating a new schema. The
Create new schema option is selected for you.
Complete the following fields and click Next:
Schema prefix field DEV Schema password field Enter a password that is at least nine characters or greater. Confirm schema password field Reenter the schema password. Database type drop-down list Select Oracle Database (Default). Username field Enter the nncentral user. Refer to the Add an Oracle Database User that Connects to BI Publisher for Backup and Restore Functions section for more information. Password field Enter the nncentral user password. Refer to the Add an Oracle Database User that Connects to BI Publisher for Backup and Restore Functions section for more information. Simple connect string field Use the <server_name>:<port>:<service_name> format. For example: vm:1521:AcmeBIPublisher -
In the
Port
Range window, the following default Port Range values display:
Port Range Starting Port 9500 (Default) If you need to change the start port number for the Business Intelligence (BI) and Web Logic Server (WLS) processes to use. Port Range End Port 9999 (Default) If you need to change the end port number for the Business Intelligence (BI) and Web Logic Server (WLS) processes to use. - In the Initial Application window, we recommend that you select the Clean Slate (no predefined application) option.
- In the Summary window, review your configuration and click Configure.
- In the Configuration Progress window, when the progress of the configuration is complete, click Next.
- In the Configuration Complete window, click Finish.
