PreviousNextJavaScript must be enabled to correctly display this content
Create the Boot Properties File
The post-installation process involves the creation of a
boot.properties file.
Change directories
to the BI Publisher domain. For example:
cd /home/oracle/Oracle/Middleware/Oracle_Home/user_projects/domains/bi
If the following
path does not exist on your system, create it with the mkdir command.
Otherwise, change directories from the BI Publisher domain to
servers/AdminServer/security.
For example:
