PreviousNextJavaScript must be enabled to correctly display this content
Install the Latest Java Development Kit 8
The BI Publisher WebLogic Server that is part of the
Fusion Middleware infrastructure must be installed separately before the Oracle
Fusion Middleware product. Prior to the 12c (12.2.1.2.0) release of BI
Publisher, the Fusion Middleware product was part of the Oracle Business
Intelligence Suite.
Get the latest
version of the Java Development Kit (JDK) version 8 from the Oracle customer
portal.
Save the tar.gz
file to the directory on your server where you want to install it.
Login to your
server as the root user.
Navigate to the
directory where you downloaded the tar.gz file.
Extract the tar.gz
file. For example:
- tar xzf jdk-8u144-linux-x64.tar.gz
Add the following
two lines to the /home/oracle/.bashrc file to permanently set the JAVA_HOME
environment variable and set the java binary as part of the system PATH:
