Collect Data for Devices or Device Groups
Add a Device Group
Use the following naming conventions when you add a device group:
- It must start with an alphabetic character.
- It can contain a minimum of three characters and a maximum of 50 characters.
- It can contain the following characters: alphabetic, numeric, hyphens (-), and underscores (_).
- It can be a mix of upper-case and lower-case characters.
- It cannot contain symbols or spaces.
- It cannot be the same name as an existing group name within the same level in the hierarchy (sibling).
Add a Network Function with Devices
Use this task to add a network function (NF) with devices to the default Home group or a group that you created. Once the NF is added successfully, the Oracle® Communications Report Manager plug-in is able to communicate with the devices in the NF.
Pre-requisite: If you are not using the default Home group to add an NF, you must specify a group for the NF.
Add a Collection Group
Pre-requisites: Oracle® Communications Report Manager must be installed properly and the reporting service must be operational. See the Oracle® Communications Report Manager Installation Guide for more information.
All devices that are added to a collection group must be running the same software and platform version.Additional Steps for Configuring a Collection Group that Uses SFTP
If you add a collection group and you select SFTP for the protocol that is used for sending CSV files, you must use this task to generate a host key from the push receiver (SDM server) and export it to the device(s).
See the Add a Collection Group section for more information.
Edit the Collection Group Start and End Times
The start and end times are the only parameters in a collection group that can be edited after a collection group is created.
- Expand the Report Manager.
- Click Collection Groups.
- In the Collection Groups pane, select the collection group you want to edit and click Edit.
- In the Devices tab, edit the start or end times and click Apply.
