Reports in BI Publisher
The upper-case groups (e.g., Performance, QoS, Registrations, etc.) correspond to the canned reports, while the lower-case groups (e.g., radius-stats, session-agent, sip-invites, etc.) correspond to the SBC's HDR groups. For more information about HDR groups, see the HDR Resource Guide for your software version.
Run a Canned Report
- Dashboard—Displays space used, fan speed, temperature, and voltage.
- Performance—Displays CPU, memory, registration cache, and concurrent sessions.
- QoS—Displays RFactor, major exceeded, critical exceeded, and successful sessions.
- Registrations—Displays total registrations, initial registrations, refresh registrations, and de-registrations.
- Security—Displays ACL entries, requests and message status, ACL entry promotions and demotions, and demotions.
- Session Realm—Displays calls per second, QoS RFactor, answer seizure ratio, and one-way signalling latency.
- Summary—Displays sessions, session state, dialogs, and errors.
Create a Data Model
Use this task to create a data model that is later used for a BI Publisher Oracle Communications Session Delivery Manager Report.
See the BIP product page for more options for creating data models.Create a Filter for a Session Delivery Manager Report: Example
The following example is used to create a filter with a device group, list of values, and device parameters for an Oracle Communications Session Delivery Manager report. The filter name is displayed as a drop-down list item in the report using the data model you added in the previous section.
The SQL queries must be entered exactly as they are shown in the following steps if you are going to use this example.
