Schedule a Recurring Report in BI Publisher After a report is created, you may schedule the report to run at regular intervals. If you have already created the report, from the Home tab click More, Schedule under the report you want to schedule. In the Schedule Report Job tab, select the Schedule tab to create a job. Select the frequency from the drop-down list. Select the start time and, if given, the stop time. If you want to conditionally execute reports, select the Use Trigger check box and specify the relevant data model. Enter a name for the report and click OK. Click Submit.
