Import Routes for a Route Set
When a comma-separated values (CSV) file is imported, column definitions and minimum fields are required in the file. Formulas specified in Oracle Communications Route Manager during the import process are applied globally and stored with each record during the importation process.
A value supplied in the formula field of a record has precedence over the formula specified in Oracle Communications Route Manager during the importation process. Order and precedence determine order of the numbers in the XML file, with the lowest appearing first.
You must specify the CSV file and the file format and allow the mapping of CSV columns to Oracle Communications Route Manager properties. Finally, a confirmation displays of what is imported, including a display of error messages.
The route set version increments after you commit the route set.
. The name of the user who locked the route set is listed.
