| Name field
The new import template name.
| Operation drop-down
list
Select a row number to map it to the
corresponding Operation row in the CSV file from the drop-down list.
| pub id drop-down
list
corresponding Pub ID row in the CSV file from the drop-down list.
| Additional PubId
Properties menu
Click the arrow icon to expand the following
Pub Id property entries that can be mapped to their corresponding CSV file
column number:
| Session Establishment Data
(SED) drop-down list
Select the numerical entry for the next hop
formula that generates the Session Establishment Data (SED).
| Order drop-down list
Select the numerical entry that is used as a
mechanism for sorting the display of route records in the application or order
the output of routes in the LRT that have the same pub-id. The order of display
or output is lowest numerical value to highest.
| Preference drop-down
list
the output of routes that have the same pub-id and order. The order of display
| Destination
Group($DESTGROUP) drop-down list
Select the numerical entry that is used as the
group of public identifiers that have an object in common. That object stores
information that can be used to select a subset of the route set for an
operation, for example for global replacement.
| Additional SED
Properties menu
SED property entries that can be mapped to their corresponding CSV file column
number:
- Imported SED
formula—Select the numerical entry for the alphanumeric string that
contains an expression used to define string concatenation and text replacement
to generate the SED for a route record.
- Next Hop
($NEXTHOP)—Select the numerical entry for the IP address, FQDN,
session agent name, or session agent group name that can be used in the formula
- Trunk Group
($TRUNKGROUP)—Select the numerical entry for the alphanumeric
string that can be used in the formula to generate the SED for a route record.
- Trunk Context
($TRUNKCONTEXT)—Select the numerical entry for the alphanumeric
- Routing Number
($RN)—Select the numerical entry for the telephone number or prefix
- Carrier Identification Code
($CIC)—Select the numerical entry for the numeric value used in the
- User 1 through
User 5 —Select the numerical entry for the alphanumeric value with a
user-specific definable meaning that can be used in the formula to generate the
SED for a route record. It can also be used for aggregating route records into
groups. Once defined, use of this field must be consistent within the route
set.
- SED Formula—The
numerical entry for the alphanumeric string that contains an expression used to
define string concatenation and text replacement to generate the SED for a
route record.
