Search for Route Sets
- Expand the Route Manager slider, and click Route sets.
Select the
Route
Search tab and complete the following fields:
Route Set Type The SBC radio button is selected by default for the Session Border Controller (SBC) route set type. The DSC option is deprecated. *pub-id (e.g. NPA-NXX) field The pub-id to use as search criteria. You can use the asterisk (*) as a wildcard. Select route sets to search section Check the Route Sets check box to search all route sets in the list. Filter by device drop-down list Use the scroll bar to see this field if it does not at first appear on your screen. Select a device to filter by this device. The route sets are checked for this selected device type. - Click Search. The results appear at the bottom of the screen. You can page through the results.
- Click Refresh to refresh the display.
- Select a table row and either click Edit to access the Edit Route dialog box to modify the route, or click Delete to delete the route from the route set.
