PreviousNextJavaScript must be enabled to correctly display this content
Compare Route Sets
Use this task when comparing the contents of a route set
with the route set contained in the LRT file of an active device before
updating the contents of the route set.
Expand the
Route
Manager slider, and click
Route
sets.
Select the
Route Set
Compare tab, and complete the following fields:
Route Set Type field
The
SBC radio button is
selected by default for the Session Border Controller (SBC) route set type. The
DSC option is deprecated.
Route Set 1
drop-down list
Select the first route set.
Route Set 2
drop-down list
Select the second route set. The
Compare button is
activated.
Click
Compare.
A progress bar appears while the comparison is
processed. When complete, the results are displayed in two columns at the
bottom of the screen. If the contents are identical between the two, messages
appear in both columns.
