Edit Route Set Information
You can update the description and notes for a route set only.- Expand the Route Manager slider, and click Route sets.
In the
Route
sets tab, select the route set and click
Lock.
The lock state toggles from unlocked, indicated by
, to locked, indicated by
. The name of the user who locked the route set is listed.
- With the locked route set selected, click Edit.
In the
Edit Route
Set dialog box, complete the following fields:
Description field (Optional) Enter a description for this route set. Notes field (Optional) Enter a note for this route set. -
Click
OK.
The route set version increments after you commit the route set.
