Basic Route Manager Functionality
You can use the Oracle Communications Route Manager application to update local route table (LRT) data on a single device or on multiple devices, provision large LRTs across multiple SBCs and Session Routers for numeric-based routing, and do the following:
Import routes from a comma-separated value (CSV) file that contains routing information.
- Assign a list of devices to a route set.
- Generate an LRT file, which contains an XML route table, from a route set.
- Push an LRT file to all assigned devices.
- Refresh LRT data on a device using the LRT file that was pushed.
Back up, restore, and rollback route sets if necessary.
Before you can work with route sets in the Route Sets tab, you must lock the route set. Only users with full permission granted can lock and unlock route sets. See the Apply User Group Privileges for Route Manager section in the Security Manager chapter of the Oracle Communications Session Delivery Manager Administration Guide for more information. - Add and manage route sets.
Add routes to route sets or modify routes in a route set.
Maintain a history of route changes and system updates through audit log capabilities in Oracle Configuration Session Delivery Manager.
Provide global search and replace capabilities.
