Basic Route Manager Components
When you use Oracle Communications Route Manager, you work with several components, including CSV and LRT files, route sets, routes and devices.
CSV File
The following CSV file fields must be specified to import a CSV file that is used to build XML route tables:
- operation—Add or delete operations for routes in a route set
- public identifier (pub-id)—A public identifier in the form of a telephone number or prefix (for example, NPA-NXX) used in LRT lookup. It is referred to in the LRT XML as object “user” of type “E164”. The Pub Id (or the Pub Id formula and the associated fields required to generate Pub Id): identified in the LRT XML as the object “next” of type “regex”. The Pub Id can be a string value if the route set’s Pub Id type is set to string. Pub Id can be directly imported or edited or it could be the result of the record’s formula. The regex in the LRT file is the URI scheme used by the network attribute to route the call.
- Session establishment data (SED or the SED formula and the associated fields required to generate SED)—Identified in the LRT XML as the object “next” of type regex. SED can be directly imported or edited or it could be the result of the record’s formula. The regex in the LRT file is the URI scheme used by the network attribute to route the call.
Any other combination of fields can be empty, unless they are included in the formula field of the record for which an error should be reported in the import log. A formula specified in Oracle Communications Route Manager during import is applied globally and stored with each record during the import operation. A value supplied in the formula field of a record has precedence over the formula specified in Oracle Communications Route Manager during the import process. The order and preference determines the order of the numbers in the XML file. The lowest number appears first.
LRT File
The Oracle Communications Route Manager application creates an LRT file by first importing individual routes from a CSV file. These routes are stored in the database and grouped into a route set. The database also contains a list of devices that the LRT file resides upon. This list is used when an update task refreshes the LRT information for a specific route set. The LRT file is gzipped and placed at a specified location on the device. Once the file has been successfully transferred to a device, an action can be issued to each device to load the file. The LRT file location on the device is /code/lrt. You can also import an LRT file from a device into Oracle Communications Route Manager. See the View LRT Files section for more information.
<?xml version="1.0" encoding="UTF-8"?>
<localRoutes>
<route>
<user type="E164">9999999</user>
<next type="regex">!^.*$!sip:04580090001@192.168.202.34:5060!</next>
</route>
<route>
<user type="E164">98888888</user>
<next type="regex">!^.*$!h323:\7777777@172.16.202.33:1720!</next>
</route>
<route>
<user type="E164">7777777</user>
<next type="regex">!^.*$!sip:8888888@192.168.202.34:9001!</next>
<next type="regex">!^.*$!sip:8888888@192.168.202.35:9001!</next>
<next type="regex">!^.*$!sip:8888888@192.168.202.36:9001!</next>
</route>
<route>
<user type="E164">7817654321</user>
<next type="regex">!^.*$!sip:7817654321@192.168.200.223:5060!</next>
</route>
<route>
<user type="E164">9817654321</user>
<next type="regex">!^.*$!sip:9817654321@172.16.0.223:5060!</next>
</route>
<route>
<user type="E164">10061</user>
<next type="regex">!^.*$!sip:10061@172.16.0.198:5060!</next>
</route>
</localRoutes>
Route Set Properties
The following table contains a list of route entries and a description of each that can be imported from a CSV file or entered through the GUI.
| Name | Description |
| Order | The numerical value used as a mechanism for sorting the display of route records in the application or order the output of routes in the LRT that have the same pub-id. The order of display or output is lowest numerical value to highest. |
| Preference | The numerical value used as a mechanism for sorting the display of route records in the application or order the output of routes that have the same pub-id and order. The order of display or output is lowest numerical value to highest. |
| Destination Group | The group of public identifiers that have an object in common. That object stores information that can be used to select a subset of the route set for an operation, for example for global replacement. |
| Next Hop | The IP address, FQDN, session agent name, or session agent group name that can be used in the formula to generate the SED for a route record. |
| Trunk Group | The alphanumeric string that can be used in the formula to generate the SED for a route record. |
| Trunk Context | The alphanumeric string that can be used in the formula to generate the SED for a route record. |
| Routing Number (RN) | The telephone number or prefix that can be used in the formula to generate the SED for a route record. |
| Carrier identification code ($CIC) | The numeric value that can be used in the formula to generate the SED for a route record. |
| User 1 through User 5 | The alphanumeric value that has a user-specific definable meaning that can be used in the formula to generate the SED for a route record. It can also be used for aggregating route records into groups. Once defined, use of this field must be consistent within the route set. |
| SED Formula | The alphanumeric string that contains an expression used to define string concatenation and text replacement to generate the SED for a route record. |
| Pub Id Formula | The alphanumeric string that contains an expression used to define string concatenation and text replacement to generate the Pub Id for a route record. |
| NPA, NXX, Puser1, Puser2 | The alphanumeric value that has a user-specific definable meaning that can be used in the formula to generate the Pub-Id for a route record. It can also be used for aggregating route records into groups. Once defined, use of this field must be consistent within the route set. |
