PreviousNextJavaScript must be enabled to correctly display this content
Load an Offline Configuration
Use this task to configure, modify, and edit
parameters for your offline configuration for your system domain.
For Oracle Enterprise products,
the following procedure supports only the Enterprise Session Border Controller
(ESBC).
On the
Configuration
Manager slider, select
Configuration tools,
Offline
configurations.
In the
Offline
Config tab, select the offline configuration that you want to use
from the table, and click
Load.
In the
Success dialog,
click
OK.
The system expands the configuration
navigation tree under the
Offline
Configurations folder in the navigation pane. You can use this
navigation tree to get to the required configuration elements.
Navigate the
offline configuration and configure, modify, and edit parameters in your
offline configuration.
