Add an Offline Configuration
You can either add an offline configuration by copying a managed device configuration or from an existing supported software schema in OCSEM.
Add an Offline Configuration from a Managed Device
You can seed a configuration from a from an existing managed device configuration.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).Load the new offline configuration and modify any of the pre-populated base parameters, as needed for your domain.
Add an Offline Configuration from a Software Version
You can seed a configuration from a supported software version schema.
Add an Offline Configuration by Copying a Template
Use this task to copy an existing offline configuration or a pre-packaged offline configuration template to make a new offline configuration for your domain.
