Information for Oracle Interactive Session Recorder Users
The Oracle Communications Session Element Manager (OCSEM) Enterprise Utilities plug-in supports using the Oracle Interactive Session Recorder (ISR) with the Device Manager. OCSEM does not support the ISR in any of the other sliders.
Once the Enterprise Utilities plug-in is installed, you can launch the
ISR login page. You can add and manage devices in
Device
Manager with the following exceptions:
- OCSEM does not support applying work order administration to the ISR, even though a work order displays the ISR as a selection.
- OCSEM does not support the Show Details functionality for the ISR.
Note that the Managed Devices - Group View page in SEM
displays the following additional controls for working with Enterprise
Plug-ins.
- Add—Launch the SEM dialogs for adding Enterprise devices.
- View—View the selected Enterprise device.
- Launch—Launch the login page for the selected Enterprise device.
Refer to the Device Manager chapter for more information.
