Information for Oracle Enterprise Operations Monitor Users
The Oracle Communications Session Element Manager (OCSEM) Enterprise Utilities plug-in supports using the Oracle Enterprise Operations Monitor (EOM) with the Device Manager to add and manage devices and device groups. OCSEM does not support the EOM in any of the other sliders.
Once the Enterprise Utilities plug-in is installed, you can launch the
EOM login page. You can add and manage devices in
Device
Manager with the following exceptions:
- OCSEM does not support applying work order administration to the EOM, even though a work order displays the EOM as a selection.
- OCSEM does not support the Show Details functionality for the EOM.
Note that the Managed Devices - Group View page in SEM
displays the following additional controls for working with Enterprise
Plug-ins.
- Add—Launch the SEM dialogs for adding Enterprise devices.
- View—View the selected Enterprise device.
- Launch—Launch the login page for the selected Enterprise device.
Refer to the Device Manager chapter for more information.
