View Device Group Tasks
Use one of the
following actions to access device task information that is associated with one
of the following work order types:
- All work order types—Dashboard Manager, Work order view, Work order administration.
- Software upgrade work order—Device Manager, Software upgrade, Work order administration.
- Global work order—Configuration Manager, Global Parameters, and click the Admin tab.
In the
Device
Group tasks table, the following column information is displayed:
Device group The device group name. Network function The name of the network function (NF) to which the device(s) belong. Platform The platform of the devices. SW version The software version of devices. Status A device task can have the following status: - Ready—The task is ready to run and waiting for the Oracle Communications Session Element Manager plugin to schedule it to start.
- ResetToReady— When the work order restarts, all the failed tasks are reset to this state to distinguish the initial Ready state of the task.
- Starting—The intermediate state between the Ready and Running states when users submit or resubmit the task.
- Running—The task started and is currently processing.
- Pausing— The intermediate state between Running and Paused states when you click Pause.
- Paused—The task stopped completely, which is initiated by setting an error policy to halt. You must manually resume a stopped task or abort the task.
- Success—The task completed successfully.
- Failed—The task failed during execution and any changes are rolled back.
- StartRollingBack—The task starts to abort when you click Abort.
- RollingBack—The task is executing the rollback procedure when either when you click Abort or the device task normally and automatically rollbacks due to an error during the normal execution of the device task procedures.
- RolledBack— The task is rolled back successfully.
- RollBackFailed—The task is rolled back unsuccessfully.
- Preloading—The task is loading the target software image to the device.
- PreloadPause— The task loaded the target software image and paused.
- PreloadFailed—The task failed to load the target software image to the targeted device(s).
Progress The number of the steps out of the total number of steps that must be executed for the process to complete successfully. Start time The server start date and local time at which the work order was scheduled to start or the time when a task within a work order is started. The following criteria are used: - If the work order has not reached its scheduled start time for all individual tasks for this work order to display the same start time.
- When an individual task starts, it replaces the scheduled start time with the time it started processing.
End time The end time is the server local time when the following conditions occur for this device task: - The device task finished successfully and paused.
- A failed condition has been met and the device task stopped as a result of the failure.
- The user manually stops a device task already in progress.
