View Work Order and Device Group Task Logs
Use one of the
following actions to access work order or device task information:
- Global parameter work order—Configuration Manager, Global Parameters, and click the Admin tab.
- Software upgrade work order—Device Manager, Software upgrade, Work order administration.
- All work order types—Dashboard Manager, Work order view, Work order administration.
In the
Work
orders table for a global parameter work order that is running or
executed, click
Logs to view the
following logging information:
- Pause, start or resume, abort or rollback, and commit actions.
- Pause, resume, abort or rollback, and resubmit task actions.
In the
Work
orders table for a software upgrade work order that is running or
executed, click
Logs to view the
- Software archive and software upgrade actions.
In the
Device
group tasks table for device tasks that are associated with a
global parameter work order or software upgrade work order that is running or
executed, click
Logs to view the
- Global parameter configuration changes, including addition, modification, and deletion of parameters.
