PreviousNextJavaScript must be enabled to correctly display this content
 About Fraud Protection Lists
 A Fraud Protection List (FPL) is a global,
	 user-specified list with a unique name that contains list type entries (Black
	 list, White list, Rate limit, and Call redirect) that you can specify data type
	 and data type format parameters. An FPL can also contain data entered manually
	 or data generated by a device. An FPL is used by Oracle Communications Session
	 Delivery Manager (SDM) to push targeted fraud updates from a Fraud Detection
	 and Prevention device to southbound devices that are capable of detecting
	 telephony fraud, such as an ESBC.
Fraud
	 Protection List Type Entries
The following table shows the FPL list type entries you can manage for
		the ingress realm of a southbound device:
| Black list |
Use this FPL entry to
				specify a fraudulent call based on the destination phone number or URI. You can
				add a known fraudulent destination to the blacklist by prefix or by fixed
				number. When a device receives a call to an entry on the blacklist, the system
				rejects the call according to the specified SIP response code. |
| White list |
				manage any exception to the blacklist, such as if a prefix such as 49 555 123
				is blocked by the blacklist. This also blocks calls to individual numbers
				starting with this prefix, such as 49 555 123 666. If you add a prefix or
				individual number to the white list, the system allows calls to the specified
				prefix and number. Continuing with the previous example, if you add 49 555 123
				6 to the white list, the system allows calls to 49 555 123 666, which was
				blocked by the blacklist entry of 49 555 123. |
| Rate limit |
				limit the loss of money, performance, and availability that an attack might
				cause. While local ordinances may not allow you to completely block or suppress
				communication, as with a blacklist, you may want to reduce the impact with rate
				limiting until a network engineer can analyze an attack and plan remediation.
				Note that rate limiting may not function immediately after a High Availability
				switch over because the newly active system must re-calculate the call rate
				before it can apply rate limiting. |
| Call redirect |
				send a fraudulent call to an Interactive Voice Response (IVR) system, or to a
				different route. For example, you can intercept and redirect a call to a
				revenue-share fraud target in a foreign country to an end point that defeats
				the fraud. For example, you can redirect subscribers dialing a particular
				number and URI to an announcement to make them aware that an account is
				compromised and what they should do. You can use an external server to provide
				such an announcement or you can use the E-SBC media playback
				function. |
Fraud
	 Protection List Data Types
The following data type of the Session Initiation Protocol
		(SIP) to or from header that is used in an FPL black list, white list, rate
		limit or call direct entry:
|  from-hostname |
 The hostname from the
				SIP FROM header. |
|  from-phone-number |
 The phone number
				from the SIP FROM header. |
|  from-username |
 The user name from
|  to-hostname |
				SIP TO header. |
|  to-phone-number |
 The phone number
				from the SIP TO header. |
|  to-username |
 The user name from the
				SIP TO header. |
| user-agent-header |
 The SIP User-Agent
				header. This header contains information about the client user agent
				originating the request.
Fraud
	 Protection List Data Type Formats
The following table describes the required formats for each
		data type Session Initiation Protocol (SIP) to or from header that is used in
		an FPL black list, white list, rate limit or call direct entry:
|  hostname |
 The exact IP address or
				Fully Qualified Domain Name (FQDN). |
|  username |
 The exact user name. For
				example: joe.user or joe_user. |
|  user-agent-header |
 The exact text
				match to the SIP User-Agent header. For example: equipment vendor
				information. |
|  phone-number |
 The following
				characters are allowed for a phone number:
-  Use the asterisk
					 (*) character to indicate prefix matching, but only at the end of the pattern.
					 For example, use 555* not *555. Do not use the asterisk character in any other
					 patterns, for example, in brackets [ ], parentheses ( ), or with an x.
- Use the bracket [ ]
					 characters to enclose ranges in a pattern. Syntax: [min-max]. For example:
					 555[0000-9999].
- Use parentheses ( )
					 to enclose optional digits in a pattern. For example: 555xx(xxxx) means 555
					 with between 2 and 4 following digits.
-  Use the character x
					 as a wildcard at the end of a dial pattern to mean 0-9. For example: 555xxx
					 means a number starting with 555 followed by 3 digits.
No leading zeroes or plus (+) characters are allowed.
