Realms
The following sections describe the realms performance group data that can be viewed for a Oracle Communications Session Element Manager device.
Current Details Tab
| Index | A monotonic increasing integer for the sole purpose of indexing realms. When it reaches the maximum value the agent wraps the value back to 1 |
| Name | The name of the realm for which the following statistics are being calculated. |
| Status | The current status of the specified realm, which is expressed as INS, constraintViolation, or callLoadReduction. |
| Inbound active | The number of current active inbound sessions. |
| Inbound active session rate | The current inbound session rate in CPS. |
| Outbound active sessions | The number of current active outbound sessions. |
| Outbound current sessions rate | The current outbound session rate in CPS. |
| Inbound admitted | The total number of inbound sessions during the period. |
| Inbound not admitted | The total number of inbound sessions rejected due to insufficient bandwidth. |
| Outbound admitted | The total number of outbound sessions during the period. |
| Outbound not admitted | The total number of outbound sessions rejected because of insufficient bandwidth. |
| Short sessions | The lifetime number of sessions whose duration was less than the configured short session duration. |
Average Period/State Tab
| Index | A monotonic, increasing number. When this number reaches the maximum value, the agent wraps the value back to 1. |
| Name | The hostname of the realm for which the following statistics are being calculated |
| Status | The current status of the specified realm, which is expressed as INS, constraintsviolation, or callLoadReduction. |
| Inbound high current | The highest number of concurrent inbound sessions during the period. |
| Inbound average session rate | The average rate of inbound sessions during the period in CPS. |
| Outbound high current | Highest number of concurrent outbound sessions during the period. |
| Outbound average session rate | The average rate of outbound sessions during the period in CPS. |
| Max burst rate | The maximum burst rate of traffic measured during the period (combined inbound and outbound). |
| Total seizures | The total number of seizures during the period. |
| Total answered sessions | The total number of answered sessions during the period. |
| Answer/Seizure ratio | The answer-to-seizure ratio, expressed as a percentage.For example, a value of 90 would represent 90%, or .90. |
| Average latency | The average observed one-way signaling latency during the period in milliseconds. |
| Max latency | The maximum observed one-way signaling latency during the period in milliseconds. |
Monthly Minutes Tab
| Index | A monotonic, increasing integer for the sole purpose of indexing realms. When it reaches the maximum value the agent wraps the value back to 1. |
| Realm name | The name of the realm for which the following statistics are being calculated. |
| Realm status | Current status of the specified realm, which is expressed as INS, constraintViolation, or callLoadReduction. |
| Minutes left | The number of monthly-minutes left in the pool per calendar month for a given realm. |
| Minutes rejected | The number of rejected calls due to monthly-minutes constraints exceeded. |
QoS Tab
| Index | A monotonic increasing integer for the sole purpose of indexing realms. When it reaches the maximum value the agent wraps the value back to 1. |
| Realm status | The current status of the specified realm, which is expressed as INS, constraintViolation, or callLoadReduction. |
| Period average | The average QoS factor observed during the period. |
| Period maximum | The maximum QoS factor observed during the period. |
| Period exceeded major | The peg counts the number of times the major Rfactor threshold was exceeded during the period. |
| Total exceeded major | The peg counts the number of times the major Rfactor threshold was exceeded during the lifetime. |
| Period exceeded critical | The peg counts the number of times the critical Rfactor threshold was exceeded during the period. |
| Total exceeded critical | The peg counts the number of times the critical Rfactor threshold was exceeded during the lifetime. |
