Environmental
Voltage Tab
| Index | A monotonic, increasing integer. When it reaches the maximum value the agent wraps the value back to 1. |
| Voltage type | Value which indicates the sensor monitoring
voltage. Values are:
| Description | The
description of the entity being monitored for voltage. Values are:
| Current voltage (millivolts) | The current voltage measurement, in millivolts, if available. A value of -1 indicates that the monitor cannot obtain a value. |
| Sensor state | The current state of the voltage for the
device being monitored. Values are:
| Slot ID | The slot on which this voltage is found. |
| Slot type | The type of module found in this slot. |
Temperature Tab
| Index | A monotonic, increasing number. When this number reaches the maximum value, the agent wraps the value back to 1. |
| Temperature source | The entity being monitored for temperature. |
| Description | A description of the temperature being monitored. |
| Current temperature (degrees Celsius) | The current temperature of the main board PROM in Celsius. |
| Sensor state | Current state of the temperature which can
have one of the following values:
| Slot ID | The slot on which this temperature is found. |
Fans Tab
| Location | Location
of the fan. Values are:
| Description | The
description of the fan. Values are:
| Current speed (% or range) | The current fan speed percentage. |
| Fan state | The current fan speed state. Values are:
| Slot ID | The slot in which this fan is found. |
Power Supplies Tab
| Index | A monotonic, increasing integer. When it reaches the maximum value, the agent wraps the value back to 1. |
| Location | The
location of the power supply. Values are:
| Description | The
description of the power supply. Values are:
| State | The
current state of the power supply. Values are:
Cards Tab
| Type | The
location of the phy card. Values are:
| Description | Description
| State | The
current state of the phy card. Values are:
