PreviousNextJavaScript must be enabled to correctly display this content
Refresh Performance Group Data
Use the following sections to refresh the statistics displayed for a performance group that belongs to a device.
Refresh a Performance Group
Expand the
Performance Manager slider and select
Devices.
In the
Devices pane, navigate to the device group folder you want.
Select a device in the device group folder and click
View.
The
Performance Groups folder appears in the navigation pane with performance groups below it.
Under the
Performance Groups folder, select the performance group you want.
In the performance group pane, click
Refresh.
Configure the Automatic Refresh Interval for a Performance Group
Expand the
Devices.
In the
View.
The
Under the
Auto refresh.
In the
Auto Refresh dialog box, enter the number of seconds you want to configure for the auto refresh of performance data from this device performance group.
Click
OK.
Stop the Automatic Refresh of a Performance Group
Expand the
Devices.
In the
View.
The
Under the
Stop auto refresh.
The automatic refresh function of performance data stops.
