Save Performance Group Data You can save performance group data that belongs to a device to a text file in comma separated values (CSV) format. Expand the Performance Manager slider and select Devices. In the Devices pane, navigate to the device group folder you want. Select a device in the device group folder and click View. The Performance Groups folder appears in the navigation pane with performance groups below it. Under the Performance Groups folder, select the performance group you want. In the performance group pane, click Save to file. In the browser dialog box used to save the file, select the save the file option (for example, in Firefox, select Save File). Note:The saved file is saved in the following format: <stats screen name>-<tab name>-<date> <hh-mm-ss>.csv For example: System-General-2011-06-10 13-53-21.csv Click OK to save the file to your local directory and close the window.
