Fraud Protection Manager Search Filters
The following filters can be used in Fraud Protection
		Manager when you use the
		Search function.
		Refer to individual search sections in this chapter for more information about
		the different search criteria that you can use for different Fraud Protection
		Manager search operations.
- Standard wild card
		  and
		  characters are supported.
- * matches 0 or more characters.
 - ? matches 1 character.
 - Search filters containing
		  wild card characters can be partial words that are case-sensitive. The
		  following searches for the word "Boston" as it would appear in the database are
		  correct:
- Bost*
 - Bos???
 - Bos?on
The following example shows an incorrect search for the word "Boston", because the search word does not follow the case-sensitive rule for the way that word would appear in the database:
- bost*
 - Search filters containing no wild card characters and that are case-sensitive result in an exact match.
