Configure a Global Parameter Work Order
Use the tasks in this section to configure a global parameter work order that is used to apply configuration parameter changes across a group of up to 20 targeted devices.
The parameters in the global parameter configuration are validated across multiple devices simultaneously. For success, a global parameter work order must be used across devices with the same software version and platform.Load a Global Parameter Configuration
Load a global parameter configuration for storing global parameter changes.
Configure the Global Parameter Work Order Element Criteria
Use this task to specify a criteria for one or more element attributes to which you want to apply changes on your targeted devices before you execute the global parameter work order. If there is only one attribute for a system-wide element, no criteria needs to be specified for the global parameter work order.
An element attribute is dynamic and changes depending on its type for which you are setting a criteria. Some elements may require that a criteria is specified for certain element attributes before the global parameter work order is executed.Execute a Global Parameter Work Order Manually
Once the software upgrade work order is created and its configuration is applied, it can be executed manually (unless you previously scheduled a start date and time for it to execute).
- Expand the Configuration Manager slider and click Global parameters.
 - Click the Admin tab.
 - In the Work orders table, select the work order you want to execute and click Start.
 - In the confirmation dialog box, click Yes.
 - Click Refresh to confirm the status changes for your global parameter work order from Not Scheduled to Running.
Commit a Global Parameter Work Order Manually
After a global parameter work order is executed, it must be committed to unlock the targeted devices that are associated with the global parameter work order. A global parameter work order is committed manually if the Auto commit check box is unchecked in the global parameter work order.
- Expand the Configuration Manager slider and click the Admin tab.
 - In the Work orders table, select the work order you want to commit and click Commit. A confirmation dialog box appears.
 - Click Refresh to confirm the work order status changed from Success to Committed.
