Manage the Global Parameter Configuration
View Global Parameter Configuration Changes
 View global parameter configuration changes to track any modifications that are made to the global parameter configuration schema in the Local Configuration View (LCV) that lists the element types that are added, deleted or modified.
- Expand the Configuration Manager slider and click the Global parameters.
 - In the GP Config tab, select the global parameter configuration and click View Changes.
 - The Local configuration view table appears in the content area and displays the top-level element changes for this global parameter configuration.
 - You can select a top-level element and click View Detail for further attribute modification details.
