previous
2C Monitor
A menu item is available in the 2c monitor control panel that allows the user to view the Rate Status. This menu item is made available by activating the Rate Status option on the 2c Monitor Web Parameters screen when running the OEDS Configuration Editor.
Enabling the Rate Status Menu Option on the 2C Monitor
The Rate Status menu item available when activating the Rate Status option on the 2c Monitor Web Parameters screen when running the OEDS Configuration Editor.
2C Monitor Rate Status
The Rate Status displays rate update message information for a specific date and time.
2c_monitor_rate_status
The screen displays the following message information:
