ALLOW BLOCK BOOKING FOR GDS USING RPC Application Setting
Group. OEDS |
Type. Parameter |
Application. PMS ORS |
Description. This is used to sell Room Types from a Block via the GDS only when the Block Code is mapped as a Channel Rate Code.
Property Determination.
Activation / Inactivation Rules. |
<none> |
Available Values. |
Y-Yes N-No |
Add On Licenses/Country Specifics. |
<none> |
Other Application Settings. |
<none> |
Affected Areas
Menus / Screens / Fields. |
<none> |
Reports & Report Forms. |
<none> |
Permissions. |
<none> |
Other Areas. |
<none> |
