previous
Setup Interface Parameters OXI_HUB
To set the basic functionality parameters for your interface, go to Interface Configuration>Parameters.
Parameter Groups are:
OXI_BLOCKS - Block parameters apply if your interface transmits blocks.
OXI_HUB Block Parameters
OXI_DATAMART - Data message handling.
OXI DATAMART Parameters OXI_HUB
OXI_GENERIC - Generic parameters apply to all interfaces.
OXI_HUB Generic Parameters
OXI_INVENTORY - In case your interface does not transmit full reservations and blocks both ways, inventory may be out of sync in either system and needs to be adjusted with the help of an inventory snapshot
OXI_HUB Inventory Parameters
OXI_PROFILES - Profile parameters apply to profiles transmission and determine how the ORS Match & Merge will handle profile management.
OXI_HUB Profile Parameters
OXI_RATES - Rate parameters apply if your interface transmits rates.
OXI_HUB Rates Parameters
OXI_RESERVATIONS - Reservation parameters apply if your interface transmits reservations.
OXI_HUB Reservations Parameters
OXI_STAYS - Stay parameters apply if your interface transmits stay data upload from properties to ORS.
OXI_HUB Stay Parameters
Note: Parameters in OXI_HUB always apply globally, not per property. For example a setting in OXI- V6 will apply to all properties linked to it. Be cautious when changing parameters from current settings.
