Logging In to Fraud Monitor
The Login page allows you to access Fraud Monitor. Enter your user name and password into the indicated fields, then click Sign in to proceed to the application.
Figure 1-2 shows the Fraud Monitor Login page.
In the case your user name or password are incorrect, a warning appears below the Sign in button and you'll have the opportunity to retry.
