Setting Mediation Engine Connector Configurations
The URL of Mediation Engine Connector represents the location of the Mediation Engine Connector instance.
Mediation engines use the password for authenticating probes at Mediation Engine Connector. The default password is oracle and should be changed by the administrator. Its value should be identical with the password set in the mediation engines ( Proxy authentication secret field of the System Settings panel).
Click Save to commit changes to these fields.
When using multiple Mediation Engines with a Mediation Engine Connector, you can still login into the Mediation Engine directly without using the Mediation Engine Connector.
