Applying Configuration Changes
It is important to replicate the configuration after any change related to platform devices on any Mediation Engine node. When you have finished configuring your devices, apply the configuration changes.
To apply configuration changes:
  1. In a web browser, log in to Mediation Engine Connector.
    The Mediation Engine Connector window appears.
  2. From the user list, select Settings, where user is your login name.
    The Settings window appears.
  3. Under Mediation Engines, select ME Management.
    The ME Management page appears.
  4. In the ME Management toolbar, click Replicate configuration, which propagates the changes to all your mediation engines.
  5. In the ME Management toolbar, click Save.
  6. Click Close, which closes the Settings window.
