PreviousNextJavaScript must be enabled to correctly display this content
Setting the Platform Devices for Each Mediation Engine
To set
the platform devices for each mediation engine:
In a web browser,
log in to Operations Monitor.
The Operations Monitor window appears.
From the user list,
select
Settings, where user is your login name.
The Settings window appears.
Under
Platform, select
Platform Devices.
The
Platform Devices page appears.
Select the device you wish to set as an
External device.
By default, devices are set as
Internal devices.
In the
Platform Devices
toolbar, click
Toggle external, which sets the device as an
External device and makes it visible to other mediation
engines on Mediation Engine Connector.
