Testing the Connection
To test
the connection:
- Verify the Settings window is open.
Under
Mediation Engines, select Connection test.
The Connection test page appears.
- In the Connection test toolbar, click Start Connection Test.
- Verify that the Status column displays OK, which confirms that the configuration is working and all the machines are reachable.
- Click Close, which closes the Settings window.
