PreviousNextJavaScript must be enabled to correctly display this content
Adding the Mediation Engines to the Mediation Engine Connector Node List
Adding
the mediation engines to the Mediation Engine Connector node list makes each
mediation engine available as a node in the top menu bar of Mediation Engine
Connector.
To add the mediation engines to the Mediation Engine Connector node
list:
Verify that the
Settings window is still open.
Under
Mediation Engines, select
ME Management.
The
ME Management page appears.
In the
ME Management toolbar, click
Add.
In the
Node Name column, enter a name for the mediation engine's
node.
In the
Hostname or IP column, enter the host name of the mediation
engine.
In the
Share secret
column, enter the mediation engine's authentication secret.
Repeat step 3 to step 6 for all the mediation engines in your
network.
In the
Replicate configuration, which propagates the changes to all
your mediation engines.
