Setting the Authentication of Mediation Engine Connector
Before a connection is made between Mediation Engine Connector and a mediation engine, an authentication token (password) is used to verify the authentication of Mediation Engine Connector.
All mediation engines require their own individual authentication token. Apply the following steps to each mediation engine in your network.
To set the authentication of Mediation Engine Connector:
