PreviousNextJavaScript must be enabled to correctly display this content
Active Calls Counter Panel
The Active Calls counter panel displays a chart which is computed based
on values aggregated from all mediation engines. Currently the active calls
counter is available. It is the only option present in the dashboard add panel
wizard, when you choose
Display a counter.
