Pre-requisites
Before beginning with the process of upgrading, perform the following pre-requisites.
Configuring Proxies and Repos
You are required to configure the proxies and repos.
Configure the http proxy in /etc/yum.conf file and also export the same to environment by doing the following.
In /etc.yum.conf, add the following line:
proxy=<Your_Proxy>
where, <your_proxy> is the proxy server details.
Run the following command to export to the environment:
export http_proxy=<Your_Proxy> export https_proxy=<Your_Proxy>
Run the following command to enable the required proxies in yum.conf file before upgrade:
curl -O https://yum.oracle.com/public-yum-ol7.repo mv public-yum-ol7.repo /etc/yum.repos.d/public-yum-ol7.repo yum-config-manager --enable ol7_latest ol7_UEKR4 ol7_developer_EPEL ol7_optional_latest ol7_addons ol7_UEKR3 ol7_UEKR5
Creating a Backup before Upgrading
You must create a backup of Mediation Engine (ME) and Mediation Engine Connector (MEC) before you begin upgrade.
For ME
Session Monitor provides the feature of backing up the configuration of Mediation Engine (ME) servers by using Configuration Savepoints.
For more information, see Configuration Savepoints section in Settings chapter of Operations Monitor User's Guide.
For MEC
Backup procedure is not available for probes or Mediation Engine Connector (MEC).
Perform the following to collect present data for comparing incase of any issues:
Take Platform Setup Application (PSA) Screenshots
Go through each page of PSA and make screenshots of the page for comparing with post-upgrade in case of issues.
Potential Customized Files
Ensure to make a backup cpy of all the following potential customized files:
/etc/mysql - Configuration files for MySQL stored in this directory. Make a copy of the entire directory. This is not required for probes.
/etc/iptego for version 3.3 or /opt/oracle/ocsm//etc/iptego for version 3.4 and later - Configuration files for Session Monitor services are stored here. Make a copy of the entire directory.
Any other configuration files that you consider to have changed on the server.
Capture current system diagnostics with MySQL dumps and all the hardware system configuration.
Altering Database Tables Before Upgrading To 4.1p6
For any upgrade from 3.4 to 4.1 P6 or from 4.0 to 4.1 P6, the following steps need to be followed.
The following steps need to followed before upgrading to 4.1 P6. This has to be applied to all the nodes (Mediation Engine/Mediation Engine Connector/Fraud Monitor).
