Sample Traffic Policy Configuration
The following formatted extract from traffic-policy-config shows the default policy configuration.
For this initial release of software, if you do not need to change any of the implicit defaults for the traffic policy, you do not need to configure this policy at all. The implicit default configuration for this policy is as below. If you need to change any of the parameters from the implicit default, you must name the resulting traffic policy defaultSLB1(traffic-policy-config)# show traffic-policy-config name default throttle-rate 800 max-signaling-rate 33000000 min-untrusted-pct 10 max-untrusted-pct 30 options
