Traffic Policy Configuration
This configuration record will enable management of tunnel bandwidth on a per-cluster member basis. The name of this policy will be entered into the OCSBC Tunnel Configurations.
If you do not need to change any of the implicit defaults for the traffic policy, you do not need to configure this policy at all. The implicit default configuration for this policy is as below. If you must change any of the parameters from the implicit default, you must name the resulting traffic policy default.Use the following procedure to perform traffic policy configuration if required.
