Sample SBC Tunnel Configuration
The following formatted extract from show running-config ACLI output shows a sample OCSBC (cluster member) configuration.
tunnel-config
name                           one
local-ip-address               1.1.1.100
remote-mac-address
remote-ip-address														182.16.204.210
port                           4444
protocol                       UDP
tls-profile																				TLS-LB
traffic-policy																	tp1
application                    SIP
last-modified-by               admin@console
last-modified-date             2013-11-10 23:24:15
This configuration is a per-tunnel configuration. Once configured, it will be passed on via the CCP protocol to the OCSLB in Heartbeat messages.
