Sample Cluster Configuration
The following formatted extract from show running-config ACLI output shows a sample cluster configuration.
cluster-config state enabled log-level CRITICAL auto-rebalance enabled source-rebalance-threshold 50 dest-rebalance-threshold 40 dest-rebalance-max 75 tunnel-check-interval 750 tunnel-fail-interval 10000 rebalance-request-delay 500 session-multiplier 4 rebalance-skip-ahead 0 rebalance-max-refresh 0 ignore-tgt-svcs-on-rebalance disabled atom-limit-divisor 1000 rebalance-del-app-entries disabled inactive-sd-limit 1800 red-port 2001 red-max-trans 10000 red-sync-start-time 5000 red-sync-comp-time 1000 service-port last-modified-by admin@console last-modified-date 2013-11-07 18:49:04
