| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to deactivate these controlled features, Command Class Management, IP User Interface, and Network Security Enhancements using the chg-ctrl-feat command.
The chg-ctrl-feat command uses the following parameters:
:partnum - The part number of the controlled feature being deactivated.
:status=off – used to deactivate the controlled feature.
The status of the controlled feature being deactivated must be on and is shown with the rtrv-ctrl-feat command.
Caution:
If the SEAS over IP feature is turned off, all SEAS terminal traffic stops.Caution:
If the IP User Interface (TELNET) controlled feature is deactivated, all Telnet sessions supported by this feature will be disabled. No changes can be made to the configuration of the Telnet terminals (terminals 17 through 40). Deactivating this feature will also deactivate FTP Retrieve and Replace feature. If the SEAS over IP feature is turned on, the TELNET feature cannot be turned off.Figure A-5 Deactivating Controlled Features
