| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to turn off the SEAS over IP feature using the chg-ctrl-feat command.
The chg-ctrl-feat command uses the following parameters:
:partnum - The part number of the SEAS over IP feature, 893018801.
:status=off – used to turn off the SEAS over IP feature.
The status of the SEAS over IP feature must be on and is shown with the rtrv-ctrl-feat command.
Caution:
If the SEAS over IP feature is turned off, all SEAS terminal traffic stops.The following is an example of the possible output.
rlghncxa03w 07-05-28 21:15:37 GMT EAGLE5 37.0.0 The following features have been permanently enabled: Feature Name Partnum Status Quantity SEAS over IP 893018801 on ---- The following features have been temporarily enabled: Feature Name Partnum Status Quantity Trial Period Left Zero entries found. The following features have expired temporary keys: Feature Name Partnum Zero entries found.
If the status of the SEAS over IP feature is off, or if the SEAS over IP feature is not enabled, this procedure cannot be performed.
chg-ctrl-feat command with the status=off parameter. Enter this command. chg-ctrl-feat:partnum=893018801:status=off
When this command has successfully completed, the following message should appear.
rlghncxa03w 06-10-01 21:16:37 GMT EAGLE5 36.0.0 CHG-CTRL-FEAT: MASP A - COMPLTD
rtrv-ctrl-feat:partnum=893018801 command. The following is an example of the possible output. rlghncxa03w 07-05-28 21:15:37 GMT EAGLE5 37.0.0 The following features have been permanently enabled: Feature Name Partnum Status Quantity SEAS over IP 893018801 off ---- The following features have been temporarily enabled: Feature Name Partnum Status Quantity Trial Period Left Zero entries found. The following features have expired temporary keys: Feature Name Partnum Zero entries found.
Once the SEAS over IP feature is turned off, the SEAS terminals can be changed to TELNET terminals. If you do not wish to change the SEAS terminals to TELNET terminals, skip steps 4 through 6, and go to step 7.rtrv-seas-config command.The following is an example of the possible output if the Eagle OA&M IP Security Enhancement feature is not enabled and turned on.
rlghncxa03w 07-01-23 18:46:01 EST EAGLE 37.5.0
SEASCLLI CONNECTION IPADDRESS PORT TERMINAL
TEAGLESTP001 IPMR1 192.168.25.10 2500 18
IPMR2 192.168.25.20 2600 27
The following is an example of the possible output if the Eagle OA&M IP Security Enhancement feature is enabled and turned on.
tekelecstp 07-01-23 18:46:01 EST EAGLE 37.5.0 SEASCLLI AUTHMODE ---------------------------- TEAGLESTP001 Password TERMINAL CONNECTION IPADDR PORT LOGIN HNAME ----------------------------------------------------------------------- 18 IPMR1 198.168.25.10 2500 root abaco-a 27 IPMR2 198.168.25.20 2600 root abaco-b
chg-trm command with the number of the terminals shown in step 4.For this example enter these commands.
chg-trm:trm=18:type=telnet
chg-trm:trm=27:type=telnet
When these commands have successfully completed, this message should appear.
rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0 CHG-TRM: MASP A - COMPLTD
A warning message, “Invalidating the Terminal data in SEASCFG table”, is also displayed.
rtrv-trm command with the terminal number specified in step 5. For this example, enter these commands.
rtrv-trm:trm=18
This is an example of the possible output.
rlghncxa03w 06-10-01 16:02:08 GMT EAGLE5 36.0.0
TRM TYPE LOC TMOUT MXINV DURAL SECURE
18 TELNET 1201 30 5 00:01:00 yes
TRM TRAF LINK SA SYS PU DB UIMRD
18 NO NO NO NO NO NO NO
APP APP
TRM SERV SS CARD CLK DBG GTT GWS MEAS MON MPS SEAS SLAN
18 NO NO NO NO NO NO NO NO NO NO YES NO
rtrv-trm:trm=27
27 TELNET 1203 30 5 00:01:00 yes
27 NO NO NO NO NO NO NO
APP APP
27 NO NO NO NO NO NO NO NO NO NO YES NO
chg-db:action=backup:dest=fixedcommand.These messages should appear, the active Maintenance and Administration Subsystem Processor (MASP) appears first.
BACKUP (FIXED) : MASP A - Backup starts on active MASP. BACKUP (FIXED) : MASP A - Backup on active MASP to fixed disk complete. BACKUP (FIXED) : MASP A - Backup starts on standby MASP. BACKUP (FIXED) : MASP A - Backup on standby MASP to fixed disk complete.
Figure 5-8 Turning Off the SEAS Over IP Feature
