| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to change the existing SEAS configuration using the chg-seas-config command.
The chg-seas-config command uses these parameters.
:conn – The name of the SEAS connection, either IPMR1 or IPMR2
:seasclli – The CLLI part of node name of the EAGLE consisting of one alphabetic character and up to 15 alphanumeric characters. The seasclli value is different from the EAGLE clli value that is entered with the chg-sid command. The seasclli value must also be configured on the Telcordia Message Router (CCS MR). Refer to Telcordia Configuration Specification "Telcordia Technologies System Documentation", BD-SNAM-ADMIN-4 Issue 14, November 2006.
:ipaddr – The IP address of the CCS MR.
:port – The port number of the CCS MR that the EAGLE connects to, from 1024 to 5000.
:hname – The name of the remote host of the CCS MR, 1 to 15 alphanumeric characters.
:login – The login name of the CCS MR, 1 to 15 alphanumeric characters.
:authmode – The method of authentication used for the connection. Currently, only password authentication is used for SEAS connections, so this parameter has only one value, password. This parameter is optional and does not need to be specified.
The hname, login, and authmode parameters are used only when the Eagle OA&M IP Security feature is enabled and turned on. The values for these parameters are displayed in the rtrv-seas-config output only when the Eagle OA&M IP Security feature is enabled and turned on. The status of the Eagle OA&M IP Security feature is shown in the rtrv-ctrl-feat output.
If the seasclli value is being changed, all the SEAS terminals must be taken out of service. If the connection information for one connection is being changed, only the terminal associated with this connection must be taken out of service.
Caution:
The IP address andport value combination for each SEAS connection must be unique or the chg-seas-config command will be rejected.The IP address for the SEAS over IP configuration cannot be shown as the IPADDR value in the rtrv-ip-lnk or rtrv-ftp-serv outputs, or the BPIPADDR value in the rtrv-ip-card output.
Figure 5-7 Changing the Existing SEAS Configuration
Sheet 1 of 3
Sheet 2 of 3
Sheet 3 of 3
