| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This appendix contains the procedures for establishing a secure telnet connection to the EAGLE using OpenSSH. Perform these procedures.
rtrv-ip-lnk - shows the IP addresses assigned to the IPSM, in the IPADDR columnrtrv-ip-card - shows the IP router, in the DEFROUTER field.rept-stat-card - shows the state of the IPSM, in the PST columnpass:loc=<IPSM card Location>:cmd="netstat -a" - shows the state of the ports 22 and 23 on the IPSM, in the (state) column. If the IPSM is configured correctly, the state of these ports will be LISTEN.rtrv-ctrl-feat - shows whether or not the Eagle OA&M Security Enhancement feature is enabled and turned on.Perform the Adding an E5-IPSM procedure to configure the IP addresses of the IPSM, the IP router, and to put the IPSM in service. Perform the Activating the EAGLE OA&M IP Security Enhancement Controlled Feature to enable and turn on the Eagle OA&M Security Enhancement feature.
