Go to primary content
Oracle® Communications EAGLE Database Administration - System Management User's Guide
Release 46.8
F11885 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Install the Windows OpenSSH Software
To install the software on a Windows machine, perform these steps.
  1. Go to this site: http://sourceforge.net/project/showfiles.php?group_id103886&package_id=111688.
  2. Select the setupssh381-20040709.zip file and download the file.
  3. After the file has been downloaded, run the installer and install all the components.
    The recommended folder for installing the components is C:\OpenSSH.
    After installing the software, this warning may be displayed.
    Figure C-1 OpenSSH Warning Window
    Click the OK button and perform the Establishing a Secure Telnet Connection to the EAGLE using Windows OpenSSH procedure.
