| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
Use this procedure to format the fixed disk of the
standby
E5-TDM using the
format-disk command.
The
format-disk command uses these
parameters.
:type – The type of disk
or media
being formatted.
system – A
removable media containing system data (GPLs and
the database). To format removable media, perform
Formatting Removable Media.
fixed – The fixed disk
of the standby
E5-TDM.
If aformat-disk:type=fixed command
failure causes the standby
E5-TDM to boot
continuously, insert a removable disk that has the same release as the active
E5-TDM into the
E5-MDAL. The standby
E5-TDM can then boot
off of the removable disk.
:loc – The location of
the standby E5-TDM, either 1114 or 1116.
:low – Is a check of
the disk or media being performed and any problems found on the disk or media
being repaired,
yes or
no? The
low=yes parameter performs a check of
the disk or media and any problems that are found are repaired. As an E5-TDM,
no data is destroyed during this operation. If the
low=no parameter is specified, the
check of the disk or media is not performed. The default value for this
parameter is
no.
:force – Format the disk
if the disk contains system data,
yes or
no. The default value for this
parameter is
no.
Reduce extended execution time when specifying theforce=yes option by also using the
low=no option.
:prtngrp – Indicates
which disk partition group is being formatted, the active partition group
(prtngrp=active) or the inactive partition
group (prtngrp=inactive). The default value for
the
prtngrp parameter is
active. The
prtngrp parameter can be specified only
with the
low=no parameter. Contact
My Oracle Support (MOS)
before using the
prtngrp=inactive parameter.
The database in the current (FD CRNT) partition of the active MASP must be coherent. For more information on verifying the database, refer to Verifying the Database.
Measurement collection must be turned off before the
format-disk command can be executed.
The standby fixed disk cannot be formatted if the
security log on the standby fixed disk contains any entries that have not been
copied to the
FTA area of the fixed
disk. This can be verified with the
rept-stat-seculog command. If the
security log on the standby fixed disk contains entries that have not been
copied to the file transfer area of the fixed disk, copy these entries to the
file transfer area using the
copy-seculog command.
Figure 2-13 Formatting the Fixed Disk of the Standby E5-TDM
Sheet 1 of 4
Sheet 2 of 4
Sheet 3 of 4
Sheet 4 of 4
